HOW TO
Export the floor area ratio parameters to an Excel file from ArcGIS Urban
First Published: March 25, 2024
Last Published: September 25, 2024
Summary
The floor area ratio (FAR) parameter determines the maximum building floor area allowed based on the size of the lot or land parcel. This parameter regulates the density and intensity of the development within a specific area. In ArcGIS Urban, the FAR parameter can be exported to a Microsoft Excel file by creating a scenario web scene, which generates a web scene and a hosted feature layer in ArcGIS Online. The hosted feature layer can then be exported to an Excel file and downloaded to the local folder. This method improves data usability, analysis, visualization, and sharing for professionals involved in land use and zoning regulations. This article provides the workflow to export the floor area ratio parameters to a Microsoft Excel file from ArcGIS Urban.
Procedure
To complete the following steps, the plan scenario must be added with planned developments and parcels. Refer to ArcGIS Urban: Work with building types and ArcGIS Urban: Add and edit parcels for more information.
  1. Log in to ArcGIS Urban and open the urban model.
  2. On the side panel, click Plans and select the desired plan.
Image of selecting the desired plan
  1. In the plan editor, create a scenario web scene. On the Parcels tab, drag the Built floor area ratio and Allowed floor area ratio layer visualizations (to be included in the web scene) to the box on the right side of the Create scenario web scene dialog box.
The Create scenario web scene dialog box
In ArcGIS Online, the hosted scenario feature layer and scenario web scene are created. The Built floor area ratio and Allowed floor area ratio layer visualizations are added to the scenario web scene as a group layer under the Parcels layer.
  1. In ArcGIS Online, export the hosted scenario feature layer to an Excel file. Refer to ArcGIS Online: Export data from hosted feature layers for instructions.
The Export to Excel dialog box
The image below shows the Excel file exported from the hosted scenario feature layer in the root folder on the ArcGIS Online Content page.
The Microsoft Excel file exported from the hosted feature layer
Article ID: 000031835
Software:
  • ArcGIS Online
  • ArcGIS Urban
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
