HOW TO
In ArcGIS Survey123 Connect, formulas can be applied to survey questions to set conditional formatting to hide or embed questions when a particular choice is made. For example, customizing a survey question to show a textbox and a multiple-choice question prompt when the respondent selects 'Yes' to the question.
This article provides the steps to conditionally hide and embed additional questions into a multiple-choice question in ArcGIS Survey123 Connect.
${<targetQuestionName>}='<targetChoiceSelected>'
Note: The relevant column hides the questions and clears the questions' record when the answer chosen is not relevant to the expression. In contrast, the body::esri:visible column hides the questions from view but still records the data.
${firstQues}='yes'
${firstQues}='yes'
The image below shows the additional questions embedded to a multiple-choice question when 'Yes' is selected.
Article ID: 000031366
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
