Summary
                    In ArcGIS Pro, polygon boundaries are symbolized with distinct outlines defined by different colors and widths. However, when adjacent polygons share a boundary, one of the overlapping edges is hidden by default. This reduces map readability and creates visual inconsistencies, especially when the boundaries are symbolized differently from one another, making it difficult to distinguish between the polygon features, as shown in the image below.
This article provides the workflow to display the hidden common polygon boundaries in ArcGIS Pro.
                        Procedure
                    To display hidden common polygon boundaries, adjust the polygon boundaries placement settings.
- Open the ArcGIS Pro project.
 - Specify the existing symbology offset value.
- In the Contents pane, right-click the polygon feature layer and click Symbology.
 - In the Symbology pane, click the desired class symbol on the Classes tab. In this example, the KOWLOON CITY class is selected.
 - On the Properties tab, click the Layers
 tab. - Expand Offset effect and specify the Offset value. Set a negative value to fully display the polygon boundary while keeping the boundary located inside the feature.
 - Click Apply or toggle Auto Apply on.
The image below shows the hidden common polygon boundary displayed in the map view.
The following steps apply when configuring a symbology for multiple polygons at once. Colors are automatically assigned based on the selected color scheme but can be customized as desired.
- Save the configured symbol to a style. Refer to Steps 2 through 4 in ArcGIS Pro: Save a point, line, or polygon symbol to a style for instructions.
 - Apply the saved style to the remaining polygons.
- In the Symbology pane, click Return to primary symbology page
. - On the Classes tab, click More and check the Format all symbols check box.
 - On the Gallery  tab, under Favorites, select the newly saved style.
The image below shows the style applied to each polygon in the map view.
- Customize the polygon fill colors.
. - Under Primary Symbology, click the Color scheme drop-down arrow and select a color scheme.
 - Click Color scheme options
 , and select Apply to fill and outline.
 - Customize the polygon outline colors.
- In the Symbologypane, under Primary Symbology, click Color scheme options
  and select Apply to outline. - Click the Color scheme drop-down arrow and select a different color scheme.
The image below shows the polygons with randomly assigned fill colors and outlines in the map view.
