HOW TO
Display grid labels on multiple rows in an ArcGIS Pro layout
First Published: September 20, 2023
Last Published: September 20, 2023
Summary
Grid labels in an ArcGIS Pro layout are formatted using tags. Tags can be used individually, or combined to create complex labels. This article highlights the workflow to display grid labels on multiple rows for graticule and measured grids in an ArcGIS Pro layout.
The following image shows how the labels are usually displayed.
Graticule and measured grid label before splitting
Procedure
Splitting the graticule grid label
  1. In ArcGIS Pro, create a layout for the project. Refer to ArcGIS Pro: Add a layout to your project for more information.
  2. In the Contents pane, expand Map Frame. The Grids layer is created.
  3. On the ribbon, click theĀ Insert tab.
  4. Click New Grid, under Graticule, select Black Horizontal Label Graticule.
The graticule grid type selection on ArcGIS Pro
  1. In the Black Horizontal Label Graticule pane, under Map Grid, click Components The Components icon.
  2. Under Appearance, in the Format text box, insert the following script.
<UND><dyn type="grid" units="dms.deg" decimalPlaces="0" showDirections="False" /><dyn type="grid" units="dms.deg.sym" decimalPlaces="0" showDirections="False" /></UND>
<UND><dyn type="grid" units="dms.min" decimalPlaces="0" showDirections="True" showZeroMinutes="False" showZeroSeconds="False"/><dyn type="grid" units="dms.min.sym" decimalPlaces="3" showDirections="True" showZeroMinutes="False" showZeroSeconds="False"/></UND>
<dyn type="grid" units="dms.sec" decimalPlaces="0" showDirections="True" showZeroMinutes="False" showZeroSeconds="False"/><dyn type="grid" units="dms.sec.sym" decimalPlaces="3" showDirections="True" showZeroMinutes="False" showZeroSeconds="False"/>
The image below shows the grid labels are displayed on two separate rows.
Graticule label split on multiple lines for degree, minute, seconds
Splitting the measured grid label
  1. In the Contents pane, expand Map Frame. The Grids layer is created.
  2. On the ribbon, click the Insert tab.
  3. Click New Grid, under Measured Grid, select Black Horizontal Label Grid.
  4. In the Black Horizontal Label Grid pane, under Map Grid, click Components The Components icon.
  5. Under Appearance, in the Format text box, insert the following script. Edit the placeValue from "1", "10", "1000", "10000", to "100000" to modify the digits to split into two lines.
<UND><dyn type="grid" placeValue="10000" digits="4" showDirections = "false"/></UND>
<dyn type="grid" placeValue="10000.right"/>
Measured label split on multiple lines based on the preferred multipliers
Article ID: 000031170
Software:
  • ArcGIS Pro
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
