HOW TO
Display feature information using a mouse hover in ArcGIS Instant Apps
First Published: January 15, 2024
Last Published: August 12, 2026
Summary
In ArcGIS Instant Apps, displaying feature information with a mouse hover can be accomplished using hover pop-ups in the 3D Viewer, Basic, Sidebar, or Slider app templates, which is useful when the goal is to display information without a mouse click. This article provides the workflow.
Procedure
In the 3D Viewer app
Enable hover pop-ups in the 3D Viewer app to display the feature information in a pop-up window when hovering over a feature on the 3D scene.
  1. Sign in to ArcGIS Online, and create an Instant App with the 3D Viewer template. Refer to ArcGIS Instant Apps: Choose an app template for more information.
  2. In the Scene settings on the side panel, click Select a scene to add a web scene to the 3D Viewer app.
  3. Click Back and select Step 3 Interactivity.
  4. In the Interactivity settings on the side panel, toggle Enable hover pop-up on.
alt="Turning on the Enable hover pop-up toggle button in the Interactivity settings."
Alternatively, click Search settings on the side panel, search for and click Enable hover pop-up.
Searching for the Enable hover pop-up option
  1. Click Publish.
The map below shows the feature information displayed in the pop-up window when hovering over the feature on the scene.
The feature information displayed in a pop-up window when hovering over the feature on the scene
In the Basic app
Enable hover pop-ups in the Basic app to display the feature information in a pop-up window when hovering over a feature on the map.
  1. Sign in to ArcGIS Online, and create an Instant App with the Basic template. Refer to ArcGIS Instant Apps: Choose an app template for more information.
  2. In the Map settings on the side panel, click Select a map or scene to add a map to the Basic app.
  1. Click Publish.
The map below shows the feature information displayed in the pop-up window when hovering over the feature.
The feature information displayed in the pop-up window when hovering over the feature on the map
In the Sidebar app
Enable hover pop-ups in the Sidebar app to display the feature information in a side panel when hovering over a feature on the map.
  1. Sign in to ArcGIS Online, and create an Instant App with the Sidebar template. Refer to ArcGIS Instant Apps: Choose an app template for more information.
  2. On the side panel, toggle Express off to use the full setup mode.
By default, the express setup mode is activated. Refer to ArcGIS Instant Apps: Express and full setup modes for more information.
  1. In the Turn off express mode window, click Continue.
Clicking Continue in the Turn off express mode window
  1. On the side panel, click Interactivity > Explore/navigate.
  2. Toggle Enable hover pop-up on.
  1. Click Publish.
The map below shows the feature information displayed in the side panel when hovering over the feature.
The feature information displayed in the side panel when hovering over the feature on the map
In the Slider app
Enable hover pop-ups in the Slider app to display the feature information in a pop-up window when hovering over a feature on the map.
  1. Sign in to ArcGIS Online, and create an Instant App with the Slider template. Refer to ArcGIS Instant Apps: Choose an app template for more information.
  1. Click Publish.
Article ID: 000031752
Software:
  • Other
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
