HOW TO
The RasterUtilities service is a utility service in ArcGIS Enterprise with tools to enable raster analysis and processing. In some instances, the RasterUtilities service becomes corrupted or needs to be moved to a different folder. The RasterUtilities service must be deleted and republished to ArcGIS Server to continue working as intended. This article provides the workflow to delete and republish the RasterUtilities service in the ArcGIS Server Administrator Directory.
"serviceName": "RasterUtilities",
"type": "GPServer",
"description": "The RasterUtilities service contains tools that enable raster analysis and processing.",
"capabilities": "null",
"provider": "ArcObjects11",
"clusterName": "default",
"minInstancesPerNode": 0,
"maxInstancesPerNode": 2,
"instancesPerContainer": 1,
"maxWaitTime": 60,
"maxStartupTime": 300,
"maxIdleTime": 1800,
"maxUsageTime": 600,
"loadBalancing": "ROUND_ROBIN",
"isolationLevel": "HIGH",
"configuredState": "STARTED",
"recycleInterval": 24,
"recycleStartTime": "00:00",
"keepAliveInterval": -1,
"private": false,
"isDefault": true,
"maxUploadFileSize": 0,
"allowedUploadFileTypes": "",
"properties": {
"virtualOutputDir": "/rest/directories/arcgisoutput",
"maximumRecords": "1000",
"outputDir": "/arcgis/shared/arcgisserver/arcgisoutput",
"jobsDirectory": "/arcgis/shared/arcgisserver/arcgisjobs",
"showMessages": "Warning",
"executionType": "Asynchronous",
"toolbox":
"${AGSSERVER}/framework/runtime/ArcGIS/Resources/ArcToolBox/Services/RasterUtilities.tbx",
"jobsVirtualDirectory": "/rest/directories/arcgisjobs"
"portalProperties": {
"isHosted": false,
"portalItems": [{
"itemID": "f76ce947e75a4e7db8616f3ae7ac52e8",
"type": "GPServer"
"extensions": [],
"frameworkProperties": {},
"datasets": []
Article ID: 000030166
Get help from ArcGIS experts
Start chatting now
