Summary
In ArcGIS Pro, when creating a buffer for a feature layer using the numerical values of a field, the buffer distance unit refers to the feature layer's spatial reference unit.
The Layer Properties window below shows the linear unit of the Point_sampledata layer in US Survey Feet.
This article provides the workflow to create buffers using values from an existing field in a preferred unit rather than the unit of the feature layer's spatial reference. In this example, meters is added to the field values in the 'Point_sampledata' layer using the Calculate Field tool.
Procedure
- Open the ArcGIS Pro project.
- In the Contents pane, right-click the feature layer and select Attribute Table.
- In the attribute table, click Add Field
. The Fields view opens. - Configure the fields table.
- For Field Name, specify a name for the new field. In this example, ‘RAD_UNIT’ is used.
- Double-click the Data Type column and select the Text data type. Refer to ArcGIS Pro: ArcGIS field data types for more information on field data types.
- On the Fields tab, in the Manage Edits group, click Save.
- Configure the text field using the Calculate Field tool.
- In the attribute table, right-click the header of the newly created text field and select Calculate Field.
- In the Calculate Field window, for Expression Type, select Python.
- Under the Expression section, specify the code below in the expression box. Replace <field_name> with the name of the field containing the buffer distance and <my_unit> with the intended measurement unit. In this example, meters is specified as the measurement unit.
str(<field_name>) + " <my_unit>"
- Click Verify to validate the expression.
- Click OK.
The attribute table below displays the new field populated with values of the buffer distance in meters.
- On the Analysis tab, in the Geoprocessing group, click Tools.
- In the Geoprocessing pane, search for and select Buffer (Analysis Tools).
- Specify the Buffer tool parameters.
- For Input Features, click the drop-down menu and select the feature layer. In this example, ‘Point_sampledata’ is selected.
- Rename Output Feature Class. In this example, ‘Point_buffer’ is used.
- For Distance [value or field], click the drop-down menu and select Field.
- Under Distance [value or field], click the drop-down menu and select the new field containing the values with the intended unit. In this example, ‘RAD_UNIT’ is selected.
- Click Run.
The map below shows the buffers created for the point features using the field values with the new unit of measurement in meters.
