HOW TO
Create a boundary for multiple contour feature layers in ArcGIS Pro
Last Published: March 14, 2025
Summary
Contours represent elevation or depth variations of a surface and are essential for visualizing geological structures and terrain features. Creating a boundary for contours improves mapping accuracy and geological analysis by limiting data to relevant regions, ensuring only the area of interest is analyzed. This article describes the workflow to create the boundary for multiple contour feature layers in ArcGIS Pro.
Procedure
The workflow below requires the ArcGIS Pro Standard or Advanced license.
  1. Open the ArcGIS Pro project.
For instructions to find and use a geoprocessing tool, refer to ArcGIS Pro: Find a geoprocessing tool.
  1. Merge the contour feature layers using the Merge tool.
  2. Convert the merged contour feature layer to a raster dataset using the Feature to Raster tool.
  3. Create an empty mosaic dataset in the file geodatabase. Refer to ArcGIS Pro: Create a mosaic dataset for instructions.
  4. Add the raster dataset to the newly created mosaic dataset using the Add Rasters To Mosaic Dataset tool.
    1. In the Add Rasters To Mosaic Dataset pane, for Mosaic Dataset, select the mosaic dataset created from Step 4.
    2. For Raster Type, select Raster Dataset.
    3. For Input Data, select Dataset from the drop-down list. Click the Browse icon, navigate to the location, and select the raster dataset created in Step 3.
    4. Click Run.
  5. Compute the extent of the raster in the mosaic dataset using the Build Footprints tool.
    1. In the Catalog pane, right-click the mosaic dataset and click Modify > Build Footprints.
    2. In the Build Footprints pane, for Mosaic Dataset, select the mosaic dataset from Step 4.
    3. Click Run.
  6. Use the Copy Features tool to export and convert the mosaic boundary from Step 6 into a new feature layer.
The map below shows the boundary of the contour feature layers.
The boundary of the contour feature layers
Article ID: 000035013
Software:
  • ArcGIS Pro 3 3
  • ArcGIS Pro 3 2
  • ArcGIS Pro 3 4
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
