HOW TO
Clip or extract an area of a raster image using polygon features in ArcGIS Pro
First Published: August 28, 2023
Last Published: May 5, 2026
Summary
In ArcGIS Pro, certain areas of a raster dataset can be clipped for better spatial analysis and data visualization. This article provides two workflows to clip or extract areas populated by polygon features in a raster dataset.
Procedure
Use Raster Functions to apply the Clip function to the raster
  1. Open the ArcGIS Pro project.
  2. Create polygon features on the area of the raster image that must be clipped. Refer to ArcGIS Pro: Create polygon features for instructions.
  3. Use the Clip raster function to clip the polygons from the raster image.
    1. Navigate to the top ribbon, click the Imagery tab, and in the Analysis group click Raster Functions to open the Raster Functions pane. Search and select the Clip function.
    2. In the Clip Properties pane, for Raster, click the drop-down menu and select the raster data to be clipped.
    3. For Clipping Type, click the drop-down menu and select Inside.
    4. For Clipping Geometry/Raster, click the drop-down menu and select the polygon feature layer.
    5. Check the Use input features for clipping geometry check box.
    6. Click Create new layer.
Use the Erase and Extract by Mask tool
  3. Create a new feature class with a rectangular polygon to cover the extent of the raster data containing the original polygon feature. Refer to ArcGIS Pro: Create a stand-alone feature class for further instructions.
The Erase tool requires an ArcGIS Pro Advanced license.
  1. Erase the polygon features from the rectangular polygon.
    1. Navigate to the Analysis tab and click Tools to open the Geoprocessing pane.
    2. In the Geoprocessing pane, search for and select Erase (Analysis Tools).
    3. For Input Features, click the drop-down and select the rectangular polygon covering the extent of the raster data.
    4. For Erase Features, click the drop-down and select the polygon feature layer on the raster data.
    5. Click Run.
The Extract by Mask tool requires a Spatial Analyst license.
  1. Extract the raster data.
    2. In the Geoprocessing pane, search for and select Extract by Mask (Spatial Analyst Tools).
    3. For Input raster, click the drop-down menu and select the desired raster data to be clipped.
    4. For Input raster or feature mask data, click the drop-down menu and select the output layer from Step 4.
    5. Leave the other parameters as default. Click Run.
The raster image below shows the clipped polygon features area.
Article ID: 000031013
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
