HOW TO
An image service is a web service designed to store, manage, and distribute a large collection of raster and image data. This service provides access to imagery through a web-based interface, which allows image viewing, analysis, and other image operations. In ArcGIS Pro, a portion of an image service can be exported as a new raster layer and clipped to a specific feature geometry while preserving the map extent of the feature layer using the Export Raster pane. This method improves the flexibility and efficiency of raster datasets by focusing on specific features within the larger dataset while maintaining the original geographic coverage.
This article describes the workflow to clip a raster from an image service while preserving the feature layer extent in ArcGIS Pro. The image below shows a polygon feature layer used as the clipping geometry to clip the area of the image service.
search for and select the image service from any portal collection. Refer to ArcGIS Pro: Search for content for instructions.
and select the feature layer with a predefined map extent. In this example, the polygon feature layer named LA_County is selected.
Note: The output of the Make Raster Layer tool is temporary and not retained after the session ends, unless the layer or map document is saved. To save the output layer, right-click the layer in the Contents pane and click Sharing > Save As Layer File, or use the Save To Layer File geoprocessing tool.
Note: Alternatively, clip the raster layer to the polygon geometry using the Clip function or the Extract by Mask tool. Refer to How To: Clip or extract an area of a raster image using polygon features in ArcGIS Pro for more information.
The image below shows the raster layer clipped to the polygon geometry while preserving the extent of the polygon feature layer.
Article ID: 000032806
Get help from ArcGIS experts
Start chatting now
