PROBLEM
The Clip Raster tool in ArcGIS Pro clips a portion of a raster dataset, mosaic dataset, or image service layer, and allows for extraction based on the shape or geometry of an input polygon. However, in some cases, the tool does not clip the raster data to the geometry of the selected polygon feature class.
The image below shows the raster data are not clipped to the geometry of the selected polygon feature class after running the Clip Raster tool.
The Use Input Features for Clipping Geometry check box is not checked in the Clip Raster pane before running the tool. This causes the minimum bounding rectangle to clip the data.
Check the Use Input Features for Clipping Geometry check box in the Clip Raster tool
The image below shows the raster data clipped to the geometry of the selected polygon feature class.
Article ID: 000027775
Get help from ArcGIS experts
Start chatting now
