HOW TO
Apply different colors for conditioned labeling in ArcGIS Pro
First Published: August 9, 2023
Last Published: December 26, 2024
Summary
In ArcGIS Pro, multiline labels with concatenated text (string) can be configured to display different colored text using the ArcGIS Arcade text formatting tags. In this example, the Schools_all layer contains information on education institutions in Portland such as names, types, and ZIP Codes of the school, as shown below.
The map in ArcGIS Pro
This article describes the steps to apply different colored text labels displaying the NAME, LEVEL, and ZIPCODE field values using the Labeling syntax <CLR></CLR>.
Procedure
  1. Start ArcGIS Pro and open the project.
  2. In the Contents pane, right-click the feature class and click Labeling Properties... to open the Label Class pane.
The Contents pane in ArcGIS Pro
  1. In the Label Class pane, click the Label expression The Label expression icon button and configure the following parameters.
    1. For Language, select Arcade.
    2. Specify the following script in the Expression section. Change <text1>, <fieldName1>, <firstLabel2>, <colorName>, <text2>, <fieldName2>, <colorName>, <text3>, and <fieldName3> to match the environment.
'<text1>' + $feature.<fieldName1> + Textformatting.NewLine + "<CLR <colorName> = '255'>" + '<text2>' + $feature.<fieldName2> + "</CLR>" + Textformatting.NewLine + "<CLR <colorName> = '255'>" + '<text3>' + $feature.<fieldName3> + "</CLR>"
The following code block is an example of the full working script.
'Name: ' + $feature.NAME + Textformatting.NewLine + "<CLR red = '255'>" + 'Type: ' + $feature.LEVEL + "</CLR>" + Textformatting.NewLine + "<CLR blue = '255'>" + 'ZIP Code: ' + $feature.ZIPCODE + "</CLR>"
  1. Click Verify to run a test of the expression. If the expression is valid, click Apply.
The Label Class pane in ArcGIS Pro
The map below displays the distribution of education institutions in Portland, labeled with their respective names, types, and ZIP Codes in different colored text.
Article ID: 000030963
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
