HOW TO
Alphabetically sort data in the List widget in ArcGIS Experience Builder
First Published: June 18, 2024
Last Published: June 18, 2024
Summary
In ArcGIS Experience Builder, the data in the List widget is displayed in its original order and not sorted alphabetically resulting in inefficient data search.
The image below shows the unsorted attribute data within the List widget in ArcGIS Experience Builder.
The unsorted attribute data in the List widget in ArcGIS Experience Builder
This article describes several workflows to alphabetically sort the data to be displayed in the List widget.
Procedure
Sort data through Tools in the List panel
  1. Log in to ArcGIS Online, and open the web experience.
  2. Drag and drop the List widget onto the canvas. Configure the template and data source for the widget.
  3. In the List panel, on the Content tab, expand Tools and toggle Sort on.
  4. In the menu option box, select the field to sort and click the preferred sequence. In this example, the Geological_Type field and the Ascending sequence are selected.
The List pane with the Sort button toggled on.
  1. On the canvas, click the text on the List widget. Click Dynamic content The Dynamic content button..
  2. In the Dynamic content panel, on the Attribute tab, under the list of attribute fields, select the attribute to display. In this example, Geological_Type is selected.
The Dynamic content configurations.
  1. Click the canvas to refresh the changes made on the List widget.
  2. Click Save The Save button. > Publish.
Sort data through the Data panel
  2. Click the Data The Data tab button. tab, and select the feature layer card. Click Settings The Settings button..
  3. In the feature layer window, click Sort > +Add a sort field.
  4. Select the field to sort and click the preferred sequence. In this example, the Geological_Type field and the Ascending sequence are selected.
The desired feature layer window with sorted data.
  1. Click Apply changes.
  3. On the canvas, click the text on the List widget. Click Dynamic content The Dynamic content button..
  4. In the Dynamic content panel, on the Attribute tab, under the list of attribute fields, select the attribute to display. In this example, Geological_Type is selected.
Sorting the data through the Data panel maintains the sorted order of the data in the other widgets as well.
Create a data view of the sorted data
  1. Log in to ArcGIS Online, and open the preferred web experience.
  3. On the Data views tab, click + Create a view.
  4. In the data view window, click Sort > + Add a sort field.
  5. Select the field to sort and click the preferred sequence. In this example, the Geological_Type field and the Ascending sequence are selected.
  6. Click Apply changes.
The data view configurations.
  1. Drag and drop the List widget onto the canvas. Configure the template and data source for the widget.
  2. In the List panel, on the Content tab, under Data, click the drop-down list of the added data source, and select the created data view. In this example, 'Data view 1' is selected.
The List panel configurations.
  2. In the Dynamic content pane, on the Attribute tab, under the list of attribute fields, select the attribute to display. In this example, Geological_Type is selected.
The image below shows the sorted attributes in alphabetical order in the List widget in ArcGIS Experience Builder.
The sorted attribute in alphabetical order in the List widget in ArcGIS Experience Builder.
Article ID: 000032753
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
