PROBLEM
Geoprocessing tools report "dataset does not exist" error but the data clearly does exist
First Published: May 5, 2016
Using a geodatabase feature class or table as input to a geoprocessing operation returns a "dataset does not exist" error. Yet the data clearly exists. Also, attempting to drag and drop the dataset onto a tool parameter does nothing, the parameter does not get updated.
Cause
This is caused by an invalid subtype on the dataset.
Solution or Workaround
Go to the feature class properties, click the Subtypes tab and re-enter the default subtype code. If the default is 0, click the cell with 0 and re-enter that same value. Apply the change by clicking OK.
Article ID: 000009556
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
