Frequently asked question
Why is the PDF file size exported from ArcGIS Pro larger compared to ArcMap?
First Published: December 9, 2019
Last Published: September 17, 2025
When exporting a map to a PDF file, the file exported from ArcGIS Pro has a larger size than the file exported from ArcMap. This is because while exporting, ArcGIS Pro maintains the vector contents in the map, whereas ArcMap rasterizes them. The exported PDF file size increases if there are more vector contents on the map. Below are a few methods to reduce the size of the PDF file when exporting in ArcGIS Pro.
Generalize and simplify features
Use the Generalize or Simplify Polygon tools to reduce the size of feature classes and the exported PDF. Refer to ArcGIS Pro: An overview of the Generalization toolset and AcrGIS Pro: How Simplify Line and Simplify Polygon work for more information.
Esri recommends creating a copy of the feature classes before running the tools.
Check the 'Output as Image' option
In ArcGIS Pro, share a map or layout as a vector format (EMF, EPS, PDF, SVG, SVGZ) and check the Output as Image option. Selecting this option reduces the output file size.
Article ID: 000022153
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
