Frequently asked question
Can field columns be reordered in the attribute table in ArcGIS Online Map Viewer Classic?
First Published: April 8, 2020
Last Published: March 13, 2024
Yes, it is possible to reorder field columns in the attribute table in Map Viewer Classic of ArcGIS Online. Field columns represent attributes of a layer and can be reordered based on the importance or groupings of certain attributes. Follow the instructions below to reorder field columns in the attribute table from Configure Pop-up in ArcGIS Online Map Viewer Classic.
This method is applicable to web maps, feature layers, and hosted feature layers.
  1. In ArcGIS Online, open the web map or feature layer in Map Viewer Classic. In this example, a web map named Customers is opened.
  2. In the Contents pane, navigate to the layer, and click More Options The More Options icon..
  3. Click Configure Pop-Up > Configure Attributes.
  4. In the Configure Attributes dialog box, select the desired attribute to reorder, and click either Move up or Move down. Reorder the attributes according to the desired order. Click OK.
The Configure Attributes icon.
The table below shows the initial and final attributes display, before and after the attributes are reordered for this example.
BeforeAfter
ADDRESSSTOREID
CITYCUSTID
STATEPURCHASE ($)
ZIPADDRESS
PURCHASE ($)CITY
CUSTIDZIP
STOREIDSTATE
  1. In the Configure Pop-up pane, click OK.
The reordered attributes.
  1. Save the map.
For feature layers or hosted feature layers, click More Options > Save Layer. This saves the changes to the layer. Skipping this step does not retain the changes made when the feature layer is opened in Map Viewer Classic in a different session.
Article ID: 000022958
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
