ERROR
The administrator has disabled the Services Directory
First Published: August 9, 2023
Last Published: August 13, 2023
Error Message
When attempting to access the REST endpoint of a service from Portal for ArcGIS or log in to the Services Directory, the following error message is displayed:
Error:
The administrator has disabled the Services Directory.
An error message is displayed when accessing the ArcGIS REST Services Directory.
Cause
Access to the Services Directory has been disabled.
Solution or Workaround
Use the following steps to enable access to the Services Directory in the ArcGIS Server Administrator Directory.
  1. Log in to the ArcGIS Server Administrator Directory with administrator credentials. The URL to the ArcGIS Server Administrator Directory is as follows:
https://webadaptorhost.domain.com/webadaptorname/admin
  1. Under Resources, click system > handlers > rest > servicesdirectory > edit.
  2. On the Edit Services Directory page, check the Services Directory Enabled check box.
Check the Services Directory Enabled check box to enable access to the ArcGIS REST Services Directory.
  1. Click Save.
Article ID: 000030939
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
