ERROR
Publishing failed to complete. Unable to add feature service definition. Error code 400
Last Published: March 17, 2023
Error Message
Attempts to publish a survey with ArcGIS Survey123 return the following error message:
Error:
The error message
Cause
The survey worksheet contains two or more questions with the same value. For example, in the survey worksheet, there are two unique rows with the exact same value in the 'name' column.
Solution or Workaround
To resolve this issue, ensure none of the fields contain the same value. Additionally, a folder in ArcGIS Online is created on the Content tab with files from the failed publication of the survey. This causes attempts to republish the survey to fail even after changing the values.
  1. Log in to ArcGIS Online and navigate to Content > My Content.
  2. On the left pane, under Folders, browse to the Survey-<Survey_Name> folder with the same name as the survey. This folder is created from the previous failed publishing attempt.
  3. Hover over the folder. Click Edit Folder Edit Folder icon. to modify the folder name, or Delete Folder Delete Folder icon. to remove the folder.
  4. In the survey XLSForm, open and check the survey worksheet to ensure there are no duplicate questions.
  5. Republish the survey from ArcGIS Survey123 Connect.
Article ID:000020640
Software:
  • ArcGIS Survey123 Connect
  • ArcGIS Online
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
