ERROR
Open of file "filename.kmz" failed: Parse error at line x, column y : not well-formed (invalid token)
First Published: May 5, 2016
Error Message
After converting a layer or map document to a KMZ file in ArcMap using the Layer To KML tool, the file cannot be opened in Google Earth, and a parse error regarding an invalid token is returned.
Error:
Image of the error message
Cause
This issue occurs because the layer name or one or more of the attribute fields are formatted incorrectly. There may be invalid characters such as "<" and ">" in the fields or the layer name. KML is an XML-based file format, therefore it recognizes these symbols as HTML tags. Google Earth is unable to read the field data.
Sample image of invalid characters in the attribute table
Sample image of the invalid characters in the KML
Solution or Workaround
Before converting the layer or the map document to KML, rename or remove invalid characters from the field.
Article ID: 000012488
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
