ERROR
When modifying the coded values of the domain using the ArcGIS Solutions Deployment tool, the Update Domain process fails with the following error message:
Error: Failed to update domain: ERROR: Domain is used beyond the scope of the service.
This error occurs when the hosting server (Portal for ArcGIS or ArcGIS Online) already contains a hosted feature layer with the same domain name.
Change the domain name when modifying the coded values.
Note: For more information on the issue and related workflow, refer to the following GeoNet thread: Update Definition with JSON - cannot find the file to modify.
Article ID: 000020198
Get help from ArcGIS experts
Start chatting now
