ERROR
Failed to log in. Invalid username or password specified
Last Published: January 18, 2023
Error Message
Attempts to log in to ArcGIS Server fail, and the following error message is displayed in the ArcGIS Server logs. In some cases, the error message is displayed every five minutes.
Error:
Failed to log in. Invalid username or password specified.
The image of the error message in the ArcGIS Server logs.
Cause
  • The issue may be due to corrupt or invalid connections between ArcGIS Server and ArcGIS Data Store.
  • Port 3268 is used in the Lightweight Directory Access Protocol (LDAP) connection string.
Solution or Workaround
Unregister and re-register ArcGIS Data Store to ArcGIS Server
This workflow involves unregistering and re-registering ArcGIS Data Store connections. This temporarily affects the connection between ArcGIS Server and ArcGIS Data Store. Unregistering and re-registering should have no effect on any existing data in ArcGIS Data Store. All previous services should continue to function after the re-registration. However, Esri recommends an appropriate backup solution for the ArcGIS Enterprise system be in place before proceeding.
  1. Navigate to ArcGIS Server Manager > Site > Server Configuration > Data Stores. Identify the ArcGIS Data Store used as a managed database, and click Unregister. This unregisters the identified data store as a managed database. Refer to ArcGIS Server: Unregister a data store for more information.
The image of ArcGIS Data Store being unregistered on the ArcGIS Server Manager page.
  1. Re-register ArcGIS Data Store using the Data Store Configuration wizard. Refer to ArcGIS Enterprise: Create a data store using the Data Store Configuration wizard for instructions.
The image of the Data Store Configuration Wizard window.
Use port 389 or 636
Configure the LDAP JSON string in ArcGIS Server Manager to use port 389 or 636. Refer to ArcGIS Server: Configure web-tier authentication with an LDAP directory for instructions.
Article ID: 000028110
Software:
  • ArcGIS Data Store
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
