ERROR
Attempts to run a sample notebook in ArcGIS Notebook Server return the following error message:
Error: Error opening notebook. Docker imageId '<image ID>' not found in local Docker registry. Please verify an image exists for the associated Notebook Runtime, or run the PostInstall utility.
The ArcGIS Notebook Server sample notebooks are configured to use the Standard runtime by default. This error occurs because the Standard container image that includes the Standard runtime is not installed. A user with an Advanced license must download and install both the Standard and Advanced container images.
To resolve the issue, install the Standard container image.
https://notebookserver.domain.com:11443/arcgis/admin/notebooks/runtimes/
Note: If the user has an Advanced license, the PostInstallUtility.bat -l <path of .tar.gz Docker image> command must be run twice to install both the Standard and Advanced container images.
Users are able to run the ArcGIS Notebook Server sample notebooks.
Article ID: 000021885
Get help from ArcGIS experts
Start chatting now
