ERROR
ArcGIS GeoEvent Server: An unrecoverable failure has occurred. Contact your administrator
Last Published: July 24, 2024
Error Message
After a machine reboot or upgrade to a later version, attempting to access ArcGIS GeoEvent Server returns the following error message:
Error:
An unrecoverable failure has occurred. Please contact your GeoEvent Server administrator
Cause
This issue may occur after making changes that temporarily shut down ArcGIS GeoEvent Server, causing some back-end services to not start properly. For example, the ArcGIS GeoEvent Gateway service, which is managed by Apache Kafka, may become disconnected.
Solution or Workaround
Restart ArcGIS GeoEvent Windows services
Restart the ArcGIS Server, ArcGIS GeoEvent Gateway, and ArcGIS GeoEvent services in that order, with a five-minute gap between restarting each service. Follow the steps below to do so:
  1. On the Windows taskbar, search for and select Task Manager.
  2. In the Task Manager window, click Services.
  3. Search and select ArcGIS Server. Right-click ArcGIS Server and select Restart.
  4. Repeat Step 3 to restart the ArcGIS GeoEvent Gateway and ArcGIS GeoEvent service with a five-minute gap after restarting each service.
Perform an administrative reset
Article ID: 000033088
Software:
  • ArcGIS Server
  • ArcGIS Enterprise 10 8 x
  • ArcGIS Enterprise 10 9 x
  • ArcGIS Enterprise 11 1
  • ArcGIS Enterprise 11 3
  • ArcGIS GeoEvent Server
  • ArcGIS Enterprise 11 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
