PROBLEM
After making changes that temporarily shuts down ArcGIS GeoEvent Server, such as a machine reboot or upgrading to a later version, accessing GeoEvent Manager returns the following generic error message "No service was found".
This issue occurs even if the ArcGIS GeoEvent Server Windows service has started and the Java processes are stable in the Windows Task Manager.
The Synchronization Service for ArcGIS Server failed to start, which in turn resulted in the components of GeoEvent Manager failing to start. This causes the “No service was found” error.
To regain access to GeoEvent Manager, start the Synchronization Service in the ArcGIS Server Administrator Directory by following the steps below:
Article ID: 000018678
Get help from ArcGIS experts
Start chatting now
