ERROR
Note: This article pertains to retired ArcGIS versions 8.x and 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
When loading any software from the CD, the following error may occur:
"Error 1335: The cabinet file 'ArcGIS1.cab' required for this installation is corrupt and cannot be used."
This is typically caused by corrupt download or install media.
To resolve the issue use one of the following two options below:
The first option is to copy the contents of the CD locally to the hard drive and then run the setup.exe file.Article ID: 000007271
Get help from ArcGIS experts
Download the Esri Support App
