PROBLEM
Dialog boxes in ArcCatalog or ArcMap do not display completely
First Published: May 6, 2016
Dialog boxes in ArcCatalog or ArcMap, such as Export Data, Data Frame Properties, Layer Properties, or the Identify window, are cut off. Dialog boxes do not display completely when opened.
Cause
This issue arises when values in specific registry keys become invalid or corrupted.
Solution or Workaround
Warning:
The instructions below include making changes to essential parts of your operating system. It is recommended that you backup your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
  1. Open the Registry Editor either by clicking Start > Run and typing in 'regedit' or by typing 'regedit' in the Windows Search.
  2. For ArcGIS 10.x: navigate to HKEY_Current_User\Software\ESRI\Desktop10.x\ArcMap - where 'x' is the version in use.
    For ArcGIS 9.1 - 9.3.1: navigate to HKEY_Current_User\Software\ESRI\ArcMap
  3. Right-click the registry key 'PropertySheets' and rename it to PropertySheetsOld.
Renaming the key regenerates a new key with default values that should resolve the issue. If any problems arise, it is possible rename the key back to PropertySheets to recover the old data.
Article ID: 000012739
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
