HOW TO
Triangulated irregular networks (TIN) are a form of vector-based digital geographic data constructed by triangulating a set of vertices. The connection of the vertices with a series of edges forms a network of triangles. TIN surfaces can be created from vector data, raster data, and terrain datasets.
The instructions provided describe how to create TIN triangles from contour lines.
A 3D Analyst license is required to use the tools mentioned in the instructions below.
By using the constrained Delauney triangulation, the breaklines are not densified, and each breakline segment is added as a single edge.
Article ID: 000012532
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
