BUG
When attempting to define a query layer in ArcGIS Desktop, one can encounter the following Oracle error:
Error: ORA-21500: internal error code, arguments: [%s],[%s],[%s],[%s],[%s],[%s],[%s],[%s]The error is encountered when the table's geometry attribute is st_geometry and is either defined as a subtype (st_point, st_polygon, st_linestring, etc.) or the st_geometry attribute values were created using a subtype constructor (st_point, st_pointfromtext, etc.).
When ArcGIS accesses the query layer, the binding used in Oracle to fetch the geometry binds an st_geometry type. Because the attribute or values returned from the attribute do not map to st_geometry, the Oracle internal error is encountered.
By definition, a type binding should support its subtype definitions. This limitation is currently a bug within Oracle's server.
Article ID: 000011333
Get help from ArcGIS experts
Download the Esri Support App
