PROBLEM
When the default MongoDB port 27017 is changed in the ArcGIS Monitor post-installer, only one of three entries in config.db is updated. As a result, the ArcGIS Monitor Server service stops running.
A connection is not possible due to mismatching port entries.
Follow the instructions provided to fix this issue.
Artikel-ID: 000017589
