HOW TO
In ArcGIS Web AppBuilder, the Filter widget limits the visibility of features in a layer when the expression criteria is specified. As the Filter widget references data from a hosted feature layer, adding the CSV data to the widget requires the CSV file to be published as a hosted feature layer. This article provides the workflow to enable the Filter widget in ArcGIS Web AppBuilder to reference a layer selection created from a CSV data.
The image below displays the ArcGIS Web AppBuilder with the enabled Filter widget referencing the hosted feature layer created from the CSV data file.
Artikel-ID: 000026253
