HOW TO
In ArcGIS Pro, an attribute table sometimes contains multiple fields with null values and populated with a space by default. In some instances, some tools or functions do not execute if the field is blank as shown in the image below.
This article describes the workflow to assign nulls to a blank field in ArcGIS Pro.
Note: This workflow only applies for data stored in a geodatabase and when the field is nullable. Refer to ArcGIS Pro: Export data or ArcGIS Pro: Modify field properties for more information.
None
icon to validate the expression.
The image below shows the Source field assigned with nulls in ArcGIS Pro.
Artikel-ID: 000027567
