HOW TO
Direkter Zugriff auf Offline-Bearbeitungen aus ArcGIS Field Maps von einem iOS-Gerät aus
Last Published: March 28, 2025
Zusammenfassung
ArcGIS Field Maps stores offline replicas in an SQLite database or runtime geodatabase (as .geodatabase files) before they are synchronized to the feature service. In the event the offline edits cannot be synchronized, the locally stored edits are extracted from the mobile device and converted to a file geodatabase. The instructions provided describe the steps to do this in ArcGIS Field Maps on iOS and Android operating systems, and how to work with or convert the recovered data in ArcGIS Pro.
Vorgehensweise
  1. Recover the runtime geodatabase from a mobile device
Files can be extracted from an iOS device in different ways. For instance, files can be shared from the Files app to iCloud and then downloaded from iCloud. This article describes the workflow of extracting files using Apple Devices.
  1. Ensure Apple Devices is installed on the computer.
  2. Connect the iOS device to the computer and launch Apple Devices. Ensure the device is successfully connected to the app.
  3. In Apple Devices, select Files in the left sidebar.
  4. Select Field Maps in the Apps column.
  5. Select the runtime geodatabase folder and click Save....
  6. Select a location to save the folder.
The list of apps in the Apple Devices app.
  1. Ensure the .geodatabase file is inside the folder, as shown in the image below.
The .geodatabase file in File Explorer.
  • From an Android device.
    1. Connect the Android device to the computer.
    2. Browse to the ArcGIS Field Maps folder. Below is an example of the folder path:
<Name of phone>\Internal shared storage\Android\data\com.esri.fieldmaps\files\<username>\mapareas
Path to the runtime geodatabase file in File Explorer.
Due to differences in Samsung's file architecture compared to other Android devices, replace 'Internal shared storage' with 'Internal storage' for Samsung devices.
The file path for the file geodatabase in a Samsung device.
  1. Copy the entire folder containing the .geodatabase file from the device and paste it on the local machine. Ensure the .geodatabase file is inside the folder, as shown in the image below.
If unable to browse files using the Android device, install a file explorer application to access the data.
  1. Sync the offline edits of the runtime geodatabase in ArcGIS Pro.
    1. Launch ArcGIS Pro and log in to ArcGIS Online with the same credentials used in ArcGIS Field Maps.
    2. In the Catalog pane, on the Project tab, click Folders to add a folder connection to the runtime geodatabase folder. Refer to ArcGIS Pro: Connect to a folder for instructions.
    3. Right-click the feature class and click Add To New > Map, as shown in the next image.
Right-click the feature class and few selection of options is displayed. Browse to Add To New and click Map.
  1. On the ribbon, click the Map tab, and click Sync in the Offline group, shown in the next image. The Sync tool must be active when a valid offline dataset is added to the map contents.
Select Sync in the Offline group of the Map tab on the ribbon.
Alternatively, use the following steps to convert the runtime geodatabase or mobile geodatabase to a file geodatabase using the Mobile Geodatabase To File Geodatabase tool in ArcGIS Pro.
  1. Launch ArcGIS Pro and open a project.
  2. In the Geoprocessing pane, search for the Mobile Geodatabase To File Geodatabase tool. Refer to ArcGIS Pro: Run a tool in the Geoprocessing pane for the steps to do this.
  3. In the Mobile Geodatabase To File Geodatabase pane, configure the Parameters tab as follows, and as shown in the next image:
    1. For Input Mobile Geodatabase, click Browse The Browse.... icon. to browse and select the mobile geodatabase file.
    2. For Output File Geodatabase, click Browse The Browse.... icon. to specify the location of the output geodatabase file.
    3. Click Run.
There are two tabs in the Mobile Geodatabase To File Geodatabase pane, which are Parameters and Environments. The parameters under the Parameters tab is configured. Click Run at the bottom-left of the geoprocessing pane after filling in the parameters.
The image below shows the mobile geodatabase converted to the file geodatabase in ArcGIS Pro.
In the Catalog pane, the mobile geodatabase is converted to file geodatabase and the feature class in the file geodatabase is displayed.
Artikel-ID: 000026799
Zugehörige Informationen
Zu Download-Optionen wechseln
