HOW TO
Exportieren von Rastern in das GeoTIFF-Format aus ArcMap
Last Published: August 20, 2024
Zusammenfassung
The steps provided describe how to export a raster to GeoTIFF format in ArcMap.
Vorgehensweise
  1. Add the raster to a blank mxd.
  2. Go to File > Export  Map.
  3. In the Export Map dialog, under Save as type, select TIFF.
  4. In the Options section, General tab, check Write World File, highlighted in the image below.
Export Map options, General tab
  1. On the Format tab, check Write GeoTIFF Tags and click Save, as shown in the following image.
Export map options, Format tab
Artikel-ID: 000026217
Zugehörige Informationen
Zu Download-Optionen wechseln
