HOW TO
Aufheben der Autorisierung der Single-Use-Lizenzen für ArcGIS Desktop und Engine nach dem Deinstallieren der Software
Last Published: July 21, 2023
Zusammenfassung
Instructions provided describe how to deauthorize ArcGIS Desktop and Engine after uninstalling the software.
When moving ArcGIS Desktop or Engine Single Use software to a new machine, the software must first be deauthorized and uninstalled from the existing machine and then installed and authorized on the new machine. If the software was uninstalled without deauthorizing it, use the ArcGIS Deauthorization Tool and follow these instructions to deauthorize the software.
Vorgehensweise
The ArcGIS Deauthorization Tool allows users to deauthorize licenses without having to re-install the ArcGIS Desktop or ArcGIS Engine software to complete the deauthorization.
  1. Download the ArcGIS Deauthorization Tool (4.23 MB .zip file).
  2. Extract the tool from the .zip file to a temporary location on the local machine.
  3. Open the unzipped folder and run Deauthorize.bat to deauthorize licenses.
If the deauthorization process fails, refer to How To: Recover lost licenses from My Esri to recover the licenses.
Artikel-ID: 000011179
Zugehörige Informationen
Zu Download-Optionen wechseln
