HOW TO
Instructions provided describe how to create a custom projection file for CAD data, and how to align the CAD file with other data in a projected coordinate system with units of feet, meters or other linear units.
Note: These instructions apply to ArcGIS versions 10.0 and previous. For 10.1 and later versions, please see How To: Create a custom projection file to align CAD Data in ArcMap 10.1 and above.
Note: These instructions should not be used to align CAD data with data in a Geographic Coordinate System, with units of decimal degrees.
In ArcMap, follow these steps to align a CAD file with other data by creating a custom projection file.
Note: It is helpful to write down these measurements on a piece of paper with a direction arrow indicating the direction the CAD data needs to move to align with the other data.
Note: Making the False Easting value larger moves the CAD file west. Making the False Easting value smaller moves the CAD data east.
Add or subtract the measured distance from step 3 above from the existing False Easting value, and enter the new value in the field.
Note: ArcMap calculates coordinate position to 16 significant digits, so the zeros to the right of the decimal must be retained.
Note: Making the False Northing larger moves the data south. Making the False Northing smaller moves the data north.
Note: Keep in mind that the CAD data may not align exactly with the available reference data, because of inaccuracies in one or both sets of data.
For Version 9.3.1 and earlier, the custom projection file is saved at the following locations:
Windows 2000 and Windows XP:
C:\Documents and Settings\<user_name>\Application Data\ESRI\ArcMap\Coordinate Systems
C:\Users\<user profile>\AppData\Roaming\ESRI\ArcMap\Coordinate Systems
C:\Users\<user profile>\AppData\Roaming\ESRI\Desktop10.x\ArcMap\Coordinate Systems
Note: If the AppData folder is not visible, make sure ‘Show hidden files, folders, and drives’ is checked in Folder Options.
C:\Program Files\ArcGIS\Coordinate Systems
C:\Program Files\ArcGIS\Desktop10.0\Coordinate Systems
C:\Program Files(x86)
Note: This step does not work if the CAD file has spaces in the name.
Note: If multiple CAD files in the same local coordinate system are stored in the folder, the custom projection file can be named 'esri_CAD.prj'. ArcMap recognizes this projection definition and applies the custom projection to all CAD files in the directory.The next time the CAD file is added to ArcMap, the software recognizes the projection definition, and is able to project the data on-the-fly, along with any other data in the map.
Note: Three chapters in the book titled 'Lining Up Data in ArcGIS: a guide to map projections' are devoted to detailed instructions for this process, and address such questions as identifying custom units, or creating a custom projection file for rotated CAD data, which are too technical to address in this article. For additional assistance, contact Esri Support Services on the Esri Support site, or call 888-377-4575.
Artikel-ID: 000009373
Esri Support App herunterladen
You can also download the app to access the chatbot anytime! Download it now.
