Häufig gestellte Frage (FAQ)
Was ist ein Gitter-Konvergenzwinkel?
Last Published: July 3, 2025
A Projected Coordinate System in most cases has a Central Meridian.  The Central Meridian points directly to the North (or South) Pole.
A Grid Convergence Angle is formed if a point lies near, but not on, that Central Meridian, by drawing a line from that point to the Pole.
The angle between the Central Meridian and the line from the point to the Pole is the Convergence Angle.  This is shown in the image below.
The Calculate Convergence Angle tool calculates the angle between the Central Meridian of the projected coordinate system applied to the data, and the line which intersects the point and runs from the point to the North (or South) Pole.  A Convergence Angle between the Central Meridian of UTM Zone 15 North and the USGS Survey Control Point Meade's Ranch is shown in the following illustration.grid convergence angle with respect to Central Meridian
Convergence angles cannot exist in a Geographic Coordinate System, or in some projected coordinate systems like Web Mercator, because in these coordinate systems ALL lines of Longitude point directly at the North Pole.
Artikel-ID: 000020700
Zugehörige Informationen
Zu Download-Optionen wechseln
