操作方法
Note: This article applies to retired ArcMap versions. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
将数据添加到 ArcMap 时,将使用默认符号对要素进行符号化。 提供的说明介绍了在 ArcMap 中更改默认符号的两种方法。
例如,图层 lake.shp 会自动使用名为 Lake 的填充样式来符号化图层的要素。 该样式必须属于引用的样式表。
For more information on organizing style contents, see the link in the Related Information section below.
Administrative privileges are needed to make modifications with the Advanced ArcMap Settings dialog box.
For 8.x versions, the Advanced ArcMap Settings tool is available in the ArcObjects Developer Kit. If the ArcObjects Developer Kit is not installed, see the link in Related Information section below for more information on installing the Advanced ArcMap Settings tool.
文章 ID: 000004627
获取来自 ArcGIS 专家的帮助
立即开始聊天
