HOW TO
Install the Advanced ArcMap Settings tool
Last Published: February 13, 2024
Summary
This article applies to retired ArcMap versions 8.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Some settings that control ArcMap operations are not accessible through the interface. The Advanced ArcMap Settings tool provides a way to adjust some of those settings.
Procedure
  1. Run SetupArcGIS.exe from the install location.
  2. Select Add/Remove.
  3. Expand the ArcObjects Developers Kit feature.
  4. Set the Utilities option to 'Will be installed on local hard drive' and click Next.
  5. Click Next again to install the utilities.
  6. After the install completes, navigate to Utilities:
    • For ArcGIS 8.1, from the ArcGIS folder, click Arcexe81\ArcObjects Developer Kit\Utilities\VBAdvancedSettingsUtility.
    • For ArcGIS versions 8.1.2 and higher, click \arcgis\arcexe\utilities.
  7. Double-click the AdvAMSet.exe file to start the tool.
For more information about what the Advanced Settings Utility does, refer to the MS Word document called "ArcMap Advanced Settings Registry Keys. doc" that accompanies the utility. It is found in the same directory as the utility.
Article ID: 000003442
Software:
  • ArcMap 8 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
