问题
问题:ArcGIS Field Maps 应用程序中具有可编辑图层的 web 地图显示为只读地图
Last Published: October 30, 2025
描述
The ArcGIS Field Maps app allows mobile workers to use the app in the field to collect location and fill out forms. In some instances, a web map containing editable layers and enabled for ArcGIS Field Maps mobile use is not editable in the mobile app. When searching for the web map in the app, it only appears when selecting the 'Read-only' options.
The Read-only option displays web maps that are read-only and not editable.
原因
This issue occurs when only the 'Use in ArcGIS Field Maps Mobile' option is enabled, while the 'Use in ArcGIS Collector' option is disabled in the web map settings.
解决方案或解决方法
To enable web map editing in ArcGIS Field Maps app, enable the Use in ArcGIS Collector and Use in ArcGIS Field Maps Mobile options.
  1. Log in to ArcGIS Online with an organizational account.
  2. Click Content, and click the My Content tab.
  3. Navigate to and click the web map. The item details page of the web map is opened.
  4. Click the Settings tab, and scroll down to the Web Map section.
  5. Under Application Settings, check the Use in ArcGIS Collector and Use in ArcGIS Field Maps Mobile check boxes.
Enable the 'Use in ArcGIS Collector' and 'Use in ArcGIS Field Maps Mobile' options under Applications Settings.
  1. Click Save.
  2. Open the ArcGIS Field Maps mobile app, click the Search icon. Select the Editing option, and search for the web map. The web map is listed under the editable web maps list.
The editable web map is displayed under the Editing option.
文章 ID: 000025697
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
