常见问题
常见问题解答:是否可以批量分配 ArcGIS Enterprise 许可?
First Published: March 15, 2021
Last Published: July 20, 2023
Yes. With each new release of ArcGIS Enterprise, Esri introduces changes to add new capabilities, such as cloud support, containerization options, and access to applications. At version 10.8.1, the capability to make bulk license assignments was added.
Bulk assignment is especially relevant given the recent licensing changes Esri has announced for ArcGIS for Power BI and ArcGIS Tracker. To provide this functionality to previous versions of ArcGIS Enterprise, Esri Support has created a script to assign ArcGIS Premium App licenses to multiple users in bulk. This script, tailored to ArcGIS for Power BI, is provided as an example.
This script is only required for ArcGIS Enterprise 10.8.x with respect to ArcGIS for Power BI.
Before running this script for any Premium App, ensure the existing ArcGIS Enterprise 10.7 or 10.8 license file has been edited and loaded into Portal for ArcGIS. For more information, refer to How To: Edit License Files in My Esri for Portal for ArcGIS 10.7 and later versions.
Instructions
The script and included instructions are packaged in a Jupyter Notebook. This script can be run in the following environments:
  • Jupyter Notebooks in ArcGIS Pro
  • ArcGIS Notebooks Server
  • Another Jupyter Notebooks environment, provided the ArcGIS Python API and pandas libraries are properly loaded before running
This script is comprised of four parts:
  1. Identifies the GIS and signs in the user with administrator credentials.
  2. Identifies which of the license file's premium app licenses the script will assign when executed (in this case, Power BI) and presents the number of licenses available.
  3. Identifies user types and adds them to a username list.
  4. Assigns the Power BI licenses to the users in the list and runs a final check to ensure that the licenses are added properly.
These functions must be tailored to fit your environment to work properly. While this example refers to Power BI, the script can be tailored to make other assignments of ArcGIS Premium Apps, such as ArcGIS Tracker, ArcGIS Pro, and others.
For questions about or issues with this script, please post in the ArcGIS Enterprise place in the Esri Community. Authorized callers with active maintenance subscriptions can contact Esri Technical Support with questions or issues related to assigning licenses.
For assistance customizing the script for specific environments, please reach out to Esri Services. Esri Services has introduced new lightweight retainer packages for users with small, focused needs, which may be a good fit in this scenario.
文章 ID: 000025263
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
