操作方法
操作方法:在 Site Scan Manager for ArcGIS 中计划飞行
Last Published: September 1, 2023
摘要
Instructions provided describe how to plan flights in Site Scan Manager for ArcGIS.
With this feature, it is possible to
  • Plan a flight in either Site Scan Flight or Manager
  • Plan a flight from the office, and a colleague can execute the flight plan at the jobsite
  • Plan a flight ahead of time with orthomosaics, overlays, and ground control points (GCP)
  • Plan a flight without access to an iPad. Anyone with a Full-access Site Scan account can create a flight plan in Manager, which allows more cross-team functionality and collaboration.
See the article: FAQ: What are the organizational and project roles and permissions in Site Scan for ArcGIS?
过程
  1. Log in to Site Scan Manager for ArcGIS. Once logged in, navigate to the Projects section from the left sidebar.
The Projects section in Site Scan
  1. Select any of the projects under the organization account. It is not necessary to be a project administrator to create a flight plan.
  2. Select a project in which to create a flight plan, and navigate to the Flight Plans section at the upper-left corner. View any previously planned flights (all of which are available on the Site Scan for ArcGIS Flight Planning app).
The Flight Plans section in Site Scan
  1. Click the New Flight Plan button on the top right corner to go to the map screen for the project and select the  type of flight to plan:
    • Area Survey
    • Crosshatch Survey, or
    • Inspect Mode.
A blue checkmark appears next to the Flight Mode selected.
Type of flights to plan
  1. Click Next to draw the Flight Path and select any map layers, including GCPs, previously created orthomosaics, or any of the overlays already uploaded. To restore the flight path to its original layout, use the Undo button on the bottom left of the screen.
Drawing of the Flight Path
  1. When finished with the flight path and all the necessary layers for your flight have been toggled, click the Settings button and update any of the flight settings, including:
    • Altitude
    • Gimbal Angle
    • Hatch Angle
    • photo Overlap
    • Side Overlap
    • Return Altitude
    • Video Mode (on or off)
    • Camera Model used
    • First Waypoint (closest or furthest)
The Settings section in the New Flight Plan window
  1. Once finished editing the flight settings, click Save Flight Plan and name it so the rest of the team can access it.
The Save Flight Plan window prompts
This flight plan is now accessible on the web and on the Flight Planning app. It is easy to duplicate or delete the new Flight Plan by navigating to the Flight Plans section of the project and clicking the ellipsis (...) symbol.
The Duplicate and Delete options in the Flight Plans section of the project
文章 ID: 000023043
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
