操作方法
操作方法:从 ArcGIS Pro 中的托管要素图层批量删除要素
Last Published: July 18, 2023
摘要
When attempting to batch delete features in a hosted feature layer, instead of using ArcGIS REST API, an alternative method is to use the Delete Features tool in ArcGIS Pro. Using the Delete Features tool is effective for users unfamiliar with ArcGIS REST API, as it allows overwriting the hosted feature layer after batch deleting its features, with the results reflected in ArcGIS Online. This article provides the workflow to batch delete features from a hosted feature layer in ArcGIS Pro.
过程
This workflow may take a longer processing time when deleting a large number of records.
  1. Launch ArcGIS Pro and log in to ArcGIS Online with privileges to edit features.
  2. In the Catalog pane, on the Portal tab, click My Content.
The Catalog pane
  1. Browse to and right-click the desired hosted feature layer. Click Add To New > Map.
The Catalog pane context menu
  1. Select, and delete the features. Refer ArcGIS Pro: Delete a selected feature for instructions. To select multiple features, press and hold the Shift key, and select the desired features.
The multiple selected features
If the Feature Service Editing Updates window is displayed after the features are deleted, click OK.
  1. Save the edits made. Refer to ArcGIS Pro: Save edits for instructions.
The image below shows the updated hosted feature layer on the ArcGIS Online web map.
The updated hosted features layer in the ArcGIS Online web map
文章 ID: 000024638
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
