错误
错误:FLEXlm 错误:-15 无法连接到许可服务器
Last Published: February 13, 2024
错误消息
The following error message displays when starting an ArcGIS Desktop application:
"FLEXlm Error: Cannot connect to license server. The server (lmgrd) has not been started yet, or the wrong port@host or license file is being used, or the port or hostname in the license file has been changed.
Feature: ARC/INFO
Server name: server1
License path:[Below are examples only]
@server1;c:\arcgis\arcexe82\sysgen\license.dat
@server1;c:\Prog~1\ESRI\License\arcgis9x
@server1;c:\Prog(x86)\ESRI\License\arcgis9x
FLEXlm error: -15,10. System Error: 10061 "WinSock: Connection refused"
For further information, refer to the FLEXlm End User Manual,
available at "www.globetrotter.com".
Program not run."
原因
ArcGIS cannot connect to and check out a license from a license server.
解决方案或解决方法
  1. Verify that the License Path indicated in the error message is the correct host name or IP address of the license manager system. If the License Path is 'Not_Set', then Desktop Administrator has not been configured with the location of the License Manager. See: FAQ: Why is 'Not_Set' listed in the Desktop Administrator License Manager folder?
  2. If the 'License Path' is correct, then the license manager may not be running. If the license manager system cannot be accessed, contact a license administrator for assistance. Otherwise, perform the following troubleshooting steps on the license manager system.
  3. Restart the License Manager:
    1. Click Start > Programs > ArcInfo > License Manager > License Manager Tools.
    2. Check the Configuration using Services radio button.
    3. Select the Start/Stop/Reread tab.
    4. Click Stop Server.
    5. Click Start Server.
  4. Perform a Status Enquiry to confirm that the licenses are available:
    1. Click the Server Status tab and click the Perform status enquiry button. Display Everything should be selected.
    2. Verify that there are no errors in the status enquiry. See: Checking the license server status
    3. Check the license manager log file for any errors.
    4. On the Config Services tab, click View Log. See: Problem: Messages in the license manager log file.
    5. If the status enquiry and log files do not indicate any errors, there may be a firewall running on the license manager system. See: How To: Configure Windows XP's Internet Connection Firewall to work with the License Manager.
    6. If issues persist, contact Esri Support for further assistance.
文章 ID: 000001798
接收通知并查找新问题或常见问题的解决方案
从我们全新的 AI 聊天机器人中获得简明答案和视频解决方案。
下载 Esri 支持应用程序
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
下载 Esri 支持应用程序
转至下载选项
