常见问题
常见问题解答:如何解决与防病毒软件相关的 ArcGIS Pro 性能问题(异常)?
Last Published: September 19, 2023
Anti-virus software can prevent ArcGIS Pro from quick start, or at least prevent a high-performance startup. This article introduces some recommendations for antivirus (AV) exclusions related to ArcGIS Pro that may cause this issue. This content is mainly to help administrators determine the cause of potential instability on a computer that is running a supported version of ArcGIS Pro when it is used with antivirus software.
Warning:
Esri recommends temporarily applying these procedures to evaluate the system. If system performance or stability is improved by the recommendations made in this article, contact your antivirus software vendor for instructions, or for an updated version of the antivirus software.
The following adjustments can be made to an antivirus program to make ArcGIS Pro run better:
Add exclusions by directories
The following directory-specific exclusions for ArcGIS Pro include real-time scans, scheduled scans and local scans. The directories that are listed below are default application directories, and these paths may require modification based on the specific environment.
\ArcGIS\Pro\bin and all subfolders
\ArcGIS\Pro\java and all subfolders
When excluding a directory that has a name greater than eight characters long, add both the short and long names to the exclusion list. These names are required by some AV programs to traverse the subdirectories.
Add exclusions by process executable
Use caution when adding exclusions that are based on executables, as incorrect exclusions may prevent some potentially dangerous programs from being detected. However, if it is necessary to make exclusions that are based on the process executables, use the following samples:
\ArcGIS\Pro\bin\AdjustFrameCamera.exe
\ArcGIS\Pro\bin\AdjustRPC.exe
\ArcGIS\Pro\bin\AppESRIPrintLocal.exe
\ArcGIS\Pro\bin\ArcGISCleanup.exe
\ArcGIS\Pro\bin\ArcGISHelp.exe
\ArcGIS\Pro\bin\ArcGISIndexingServer.exe
\ArcGIS\Pro\bin\ArcGISPro.exe
\ArcGIS\Pro\bin\ArcGISSharingServer.exe
\ArcGIS\Pro\bin\ArcGISSignAddIn.exe
\ArcGIS\Pro\bin\ArcGISSignOnHandler.exe
\ArcGIS\Pro\bin\ArcGISUpdate.exe
\ArcGIS\Pro\bin\ArcOSR.exe
\ArcGIS\Pro\bin\BAEngine.exe
\ArcGIS\Pro\bin\BGLCacheMgr.exe
\ArcGIS\Pro\bin\ESRIErrorReportWriter.exe
\ArcGIS\Pro\bin\ESRIReporter.exe
\ArcGIS\Pro\bin\ESRIWebReporter.exe
\ArcGIS\Pro\bin\ExcelToSQLite.exe
\ArcGIS\Pro\bin\ExcelToSQLite64.exe
\ArcGIS\Pro\bin\FilterDSM.exe
\ArcGIS\Pro\bin\FuseDSM.exe
\ArcGIS\Pro\bin\gdalserver.exe
\ArcGIS\Pro\bin\GenerateDSM.exe
\ArcGIS\Pro\bin\LocalWorker.exe
\ArcGIS\Pro\bin\ndmetis.exe
\ArcGIS\Pro\bin\osgconv.exe
\ArcGIS\Pro\bin\printgdi.exe
\ArcGIS\Pro\bin\PythonEnvUtils.exe
\ArcGIS\Pro\bin\RegisterAddIn.exe
\ArcGIS\Pro\bin\SoftwareAuthorizationPro.exe
\ArcGIS\Pro\bin\SynExpand.exe
\ArcGIS\Pro\bin\wkhtmltopdf.exe
\ArcGIS\Pro\bin\Extensions\Mapping\ReadStyleFile.exe
\ArcGIS\Pro\java\runtime\hadoop\bin\winutils.exe
\ArcGIS\Pro\java\runtime\jre\bin\jabswitch.exe
\ArcGIS\Pro\java\runtime\jre\bin\java.exe
\ArcGIS\Pro\java\runtime\jre\bin\java-rmi.exe
\ArcGIS\Pro\java\runtime\jre\bin\javaw.exe
\ArcGIS\Pro\java\runtime\jre\bin\jjs.exe
\ArcGIS\Pro\java\runtime\jre\bin\keytool.exe
\ArcGIS\Pro\java\runtime\jre\bin\kinit.exe
\ArcGIS\Pro\java\runtime\jre\bin\klist.exe
\ArcGIS\Pro\java\runtime\jre\bin\ktab.exe
\ArcGIS\Pro\java\runtime\jre\bin\orbd.exe
\ArcGIS\Pro\java\runtime\jre\bin\pack200.exe
\ArcGIS\Pro\java\runtime\jre\bin\policytool.exe
\ArcGIS\Pro\java\runtime\jre\bin\rmid.exe
\ArcGIS\Pro\java\runtime\jre\bin\rmiregistry.exe
\ArcGIS\Pro\java\runtime\jre\bin\servertool.exe
\ArcGIS\Pro\java\runtime\jre\bin\tnameserv.exe
\ArcGIS\Pro\java\runtime\jre\bin\unpack200.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\cjpeg.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\djpeg.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\fax2ps.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\fax2tiff.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\jpegtran.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\lz4.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\lzmainfo.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\openssl.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\pal2rgb.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\pngfix.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\png-fix-itxt.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\ppm2tiff.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\raw2tiff.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\rdjpgcom.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\sqlite3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiff2bw.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiff2pdf.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiff2ps.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiff2rgba.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffcmp.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffcp.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffcrop.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffdither.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffdump.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffinfo.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffmedian.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffset.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\tiffsplit.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\unxz.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\winpty-agent.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\wrjpgcom.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\xsltproc.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\xz.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\xz_static.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Library\bin\zstd.exe
\ArcGIS\Pro\bin\cef\CefSharp.BrowserSubprocess.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\distutils\command\wininst-14.0-amd64.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\pip\_vendor\distlib\t32.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\pip\_vendor\distlib\t64.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\pip\_vendor\distlib\w32.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\pip\_vendor\distlib\w64.exe
\ArcGIS\Pro\bin\Python\cwp.exe
\ArcGIS\Pro\bin\Python\res\entrypoint.exe
\ArcGIS\Pro\bin\Python\Scripts\conda.exe
\ArcGIS\Pro\bin\Python\Scripts\conda-env.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\2to3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\black.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\chardetect.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\easy_install.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\f2py.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\flake8.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\futurize.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\idle.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\iptest.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\iptest3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\ipython.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\ipython3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\isympy.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jlpm.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jsonschema.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-bundlerextension.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-console.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-contrib.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-contrib-nbextension.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-kernel.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-kernelspec.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-lab.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-labextension.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-migrate.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-nbconvert.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-nbextension.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-nbextensions_configurator.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-notebook.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-run.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-serverextension.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-troubleshoot.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\jupyter-trust.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\keyring.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\nc3tonc4.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\nc4tonc3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\ncinfo.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\nosetests.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pasteurize.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pip.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pip3.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\py.test.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pycodestyle.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pydoc.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pyflakes.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pygmentize.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pyjson5.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pyjwt.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\pytest.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\wheel.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Scripts\x86report.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\cli.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\cli-32.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\cli-64.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\gui.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\gui-32.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\setuptools\gui-64.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\testpath\cli-32.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\testpath\cli-64.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\pythonw.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\venvlauncher.exe
\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\venvwlauncher.exe
文章 ID: 000025378
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
