错误
在 Portal Administrator Directory 中,当尝试使用 importSite 操作根据备份站点配置文件恢复站点时,会返回以下错误消息:
Error: Failed to rollback. Code: 500
Note: The workarounds may require the assistance of the IT team.
Note: For Portal for ArcGIS 11.1 and later, ensure the Validate location? check box is checked in the Portal Administrator Directory when restoring the backup using the importSite operation.
对于 Portal for ArcGIS 11.0 或更低版本,请使用以下提供的解决方法。
从 Windows 文件资源管理器的路径栏中复制目录路径,然后将其粘贴到 Portal Administrator Directory 中 importSite 操作的参数框中。
为所需 Portal for ArcGIS 账户设置存储配置文件的文件夹位置的权限。
Note: To find the service account running Portal for ArcGIS, run Services on the Portal for ArcGIS machine. Identify the account on the Log On tab in the Portal for ArcGIS Properties (Local Computer) window.
文章 ID: 000032639
获取来自 ArcGIS 专家的帮助
立即开始聊天
