操作方法
尝试在 ArcGIS Pro 中与企业级地理数据库建立数据库连接失败,并返回以下错误消息:
Error: Failed to connect to database. No ArcGIS Server license found. Contact your geodatabase administrator to update license
ArcGIS Server 许可过期。 用于在 ArcGIS Server 中创建连接的密钥代码文件与 ArcGIS Server 授权文件一起过期,由此导致数据库断开连接。
Note: Only a geodatabase administrator can apply the workflows provided below. Refer to ArcGIS Pro: Geodatabase management for more information.
C:\Program Files\Esri\Licenses<version>\sysgen
/arcgis/server/framework/runtime/.wine/drive_c/Program Files/ESRI/License<version>/sysgen
Note: For ArcGIS Pro with no ArcGIS Server installed, refer to How To: Generate a keycodes file to authorize an enterprise geodatabase when an ArcGIS Server instance is unavailable for instructions to generate the new keycodes file.
文章 ID: 000031685
获取来自 ArcGIS 专家的帮助
立即开始聊天
