操作方法
Note: This article applies to retired ArcMap versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
shapefile 和地理数据库要素类的自定义地理(基准面)变换无法在 ArcToolbox 中使用,但可以通过完成以下步骤在 ArcMap 中使用。
At versions after 9.1, a custom geographic (datum) transformation can be saved to disk using the Create Custom Geographic Transformation tool in ArcToolbox.
Warning:
Do not change the GCS listed in the 'Into...' box in this dialog box.
Be sure to include the correct sign for the transformation parameter values. If the parameter value is negative, the value entered must include the '-' (minus) sign.
文章 ID: 000005629
获取来自 ArcGIS 专家的帮助
立即开始聊天
