Instrução
In ArcGIS Pro, labels are descriptive text for features in maps and scenes. Labels are dynamically placed on the map, and the text string is derived from one or more feature attributes. Labels can be customized to display different text formatting and also change the appearance of the label styles for lines, points, and polygons.
By default, labels are fixed in place and do not rotate with the map view. The image below displays a map that is rotated, but the label orientation remains in a horizontal position.
For a better display of map orientation, the labels can be formatted to rotate simultaneously when the map is rotated. This article provides instructions to enable label rotation when rotating the map.
The image below shows the labels rotation according to the map rotation.
ID do Artigo: 000026151
Comece a conversar agora
