Instrução
When using ArcGIS License Manager for Named User licensing in a Microsoft Azure virtual machine environment, the license manager requires additional configuring to ensure it is accessible. Additional configurations involve defining the appropriate host name in the license manager, including the vendor daemon in the license manager service.txt file, and opening the relevant ports in the virtual network to allow the vendor daemon and license manager to communicate seamlessly.
If a license manager is not properly configured for Azure, the following error may be returned when trying to access ArcGIS Pro:
Error: A valid ArcGIS License Manager for your Licensing Portal could not be found on the specified host. Please contact your organization's License Administrator to ensure that your ArcGIS License Manager is running and accessible.
Change the host name for the License Manager to the public-facing host name
https://<machine_name>.<domain>.com/<webadaptor>/portaladmin
Edit the service.txt file to include the vendor daemon
C:\Program Files (x86)\ArcGIS\LicenseManager\bin\Service.txt
VENDOR ARCGIS PORT=5152
Ensure the ArcGIS License Manager and vendor daemon ports are open in the Azure virtual network and Azure Application Gateway
Ensure the ports listed in the ArcGIS License Manager service.txt file are available for use by configuring the virtual network, the Azure Application Gateway, and the machine's firewall. This process can only be done by the organization's Azure administration team.
ID do Artigo: 000024588
Comece a conversar agora
