方法
A map in ArcGIS Pro displays a collection of layers drawn in a particular order for a given geographic extent and projection. The map can be rotated to a specific angle to provide the proper perspective. In ArcGIS Pro, maps can be rotated in both the map view and layout view.
Use one of the following options to rotate the map in ArcGIS Pro:
Insert the rotation angle in the Map Properties dialog box
This option is applicable to both map view and layout view.
Use the on-screen navigator
ArcGIS Pro 2.0 and above provides an on-screen navigator for quick access to controls that help refine perspective and scale when moving through maps and scenes. In map view, use the Full Control mode of the navigator options to rotate the map. Refer to ArcGIS Pro: Use the on-screen navigator for more information.
Note: There are keyboard shortcuts to rotate the map. Click the map, hold the left mouse button, and press 'A' to rotate counter clockwise or 'D' to rotate clockwise. Refer to ArcGIS Pro: Keyboard shortcuts for navigation for more information.
Insert rotation angle in the Element pane
This option rotates only the map frame in the layout view, and not the map referenced by the map frame. To rotate the referenced map, follow the first option above.
Note: In the layout view, the map frame can be rotated manually by moving the rotation handle at the corner of the map frame.
記事 ID: 000021778
ArcGIS エキスパートのサポートを受ける
今すぐチャットを開始
